OctaneRender® for 3ds max® v3.08 - 5.08 [OBSOLETE]
acc24ex
paride4331 wrote:
acc24ex wrote:PLZ
Solve the renderable bug, it never refreshes until you reload the viewport.. it's an essential part of my workflow, I'm surprised no one reported it yet..
Hi acc24ex,
I do not know what to say, everything seems to work.
yes, what you did works, but do the copy of that instance - it will not show it on my system.. until viewport reload
.. instance to instance fine, instance to copy not fine..
.. also do renderabe object on and off ... it will turn on but not off - without viewport restart,.,
.. I think those two are relatable bugs
- also this one old issue (maybe bug) - all of my default lights have a slight blueish tint at 6500 K - isn't that supposed to be pure white?
User avatar (Default)
merid888
hi, i have a problem, i can't use the sun becouse i see the light but none shadows, i would like know why happen this
thank you for help me octane render team
add picture i am use the version 3.08-5.08 into 3ds max 2018
sun error
sun error
paride4331
Hi merid888,
cast shadow are on stage, I can see them. You can not see shadows if there is too much reflective material on the ground, that's right.
solomon
Looks like Cinema4D already got a Version 4 build... when is Max going to get V4?
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
acc24ex
..how do we use the ORC any experiences, how much is it, and requirements, cant find anything quickly regarding 3dsmax workflow
How can I get an estimate for a job?
example: my octanebench is 100, and my project takes 10 hours / around 1 minute per frame, 250 frames - how much is for the 1x speed and 10x speed and 100x speed
paride4331
acc24ex wrote:..how do we use the ORC any experiences, how much is it, and requirements, cant find anything quickly regarding 3dsmax workflow
Here https://help.otoy.com/hc/en-us/categori ... nder-Cloud is a link with further information on using ORC.
eventually you could contact Otoy support or post here:
viewforum.php?f=100
PAride
mykola1985
any news on V4 release? :?
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
coilbook
Hi Paridie,
I know i asked this question before but I just cannot get fake volume lights to look like in the picture using AO only. The light beams scatter too much for me. Do you know by any chance how to do it? This will be for the undersea look. Thank you
paride4331
coilbook wrote:Hi Paridie,
I'm not sure to understand what you mean, if you want more sharpness you could reduce size emitter (or sun).
SergKlyosov
Object layer rendering is not working with VDB volumes
Volume just disappears from the render and rendering like transparent part
I've recorded a video which is showing the issue
https://youtu.be/1MhjKLOGWKk
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
Return to “Releases”
