OctaneRender for Carrara 3.08.03.42[Stable and Test]
Carrara (Integrated Plugin developed by Sighman)
Sighman
New update has been posted to this thread...
Changed in 3.08.00.40
◾Compiled with Octane SDK 3.08 RC 2. See here for more details.
◾Added Edit button to OSL script nodes to open the Octane OSL script editor.
◾Support new volume render passes.
◾Added new pins to Metal, Displacement, and Kernel nodes.
◾Added LUT support in Imager Camera properties.
◾Added support for new Camera response curves.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
A new update has been posed to this thread:
Changed in 3.08.00.41
◾Compiled with Octane SDK 3.08 (Stable). See here for more details.
◾Added OSL Camera and OSL Baking Camera support.
◾Added a separate roughness channel for sheen.
◾Fixed interactive nature of the Octane Node Editor. (For a while now the changes made when using the Node Editor where not being applied until you closed the window. Changes in the node editor are now applied right away.)
protovu
Hi Simon,
I just installed this latest version, and it is not rendering.
I am only seeing an empty grey render viewport. Have tested several files, including a new file. Have also restarted.
dual zeon
win 7
Nvidia cards:
GTX 970, 980, and 2 Titan X
nvidia graphics driver: 376.33
Thanks for your help,
Rick
EddyMI3D
Runs fine with me.
Did you update to SDK 3.08 stable?
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
protovu
Hi Eddy,
Pardon my ignorance, but isn't the SDK for softaware developers?
You think maybe it has some bearing on the plugin?
EddyMI3D
Hello Rick,
you are right.
I mixed it up with the stand alone version.
The Stable version was published two days before 3.08.00.41
20. Apr. 2018: viewtopic.php?f=24&t=66875
22. Apr. 2018: viewtopic.php?f=79&t=56881&start=100#p336544
Eddy
My Rig:
Win 7-64
Nvidia GTX 760
Sighman
protovu wrote:Hi Simon,
Is the standalone working?
Are the devices enabled/recognized?
protovu
Using the benchmark.orbx file, the latest StandAlone 3.08, is not working.
StandAlone 3.03.04 was able to render the benchmark file.
The Carrara plugin does not show any devices, nor the ability to enable any devices.
protovu
Hi Simon,
Update:
The good news: I got the new version to work by downloading and installing the latest Nvidia driver. Both StandAlone and Plugin now work.
The not so good news: Rendering is not right, at least for several tested files. I have put together a some images within a .pdf to show you a comparison. Additionally, I have included 2 .car files for your analysis.
Thank you for your help. The new version looks promising. Seems faster?
Rick
render compare.zip
(34.18 MiB) Downloaded 887 times
protovu
Hi Simon,
Are there any other files I can provide for this? I realized the HDRI may not have come through in my export.
Return to “Carrara”
