Shader change after updating to 5.07
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
nildoe
Hello,
I have been using octane 4.43 and up to now my shaders were fine, but since I updated to 5.07 now my surfaces show up really strange..please see pic...any ideas what to do?
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
paride4331
H nildoe,
could you share (in pm if you want) your shader in a sample scene please?
nildoe
Paride I sent you a PM with a dropbox link..thanks
paride4331
Hi Nildoe,
i'm investigate about that, something goes wrong and need rebuild materials node.
attached your shader rebuilted in pm, I hope it's ok.
I will send this issue to developer, I'll keep you informed about.
nildoe
Hi Paride..
thank you so much for your help and attention..i will test and let you know...I really hope this can be fixed..i have more characters with the same issue :(
paride4331
Hi Nildoe,
did you make this shader using Octane V2?
nildoe
I honestly don't remember..but im pretty sure i made with v3.. I know that with v3-4.43 for example was working with no issues..
paride4331
Hi nildoe,
your shader works well using 4.43 but I think your shader has something wrong, impossible to reproduce, as to connect scatter node to filmwidth..
In short, shader seems right using 3.07 but shader works badly; shader seems wrong using 3.08 but shader works well.
I keep you updated.
nildoe
hmm thanks Paride..i Guess something IS wrong..i will check also
nildoe
there definetely a problem with 5.07...
this is a simple mix shader that was working also in previous 4.43...
I know that the name of the shader is Carpaint_Black, but thats because i forgot to change to white
Return to “Bug Reports”
