Hello!
I'm slowing trying to learn how to create OSL textures.
But one thing is not clear for me and I would like to have you help about that.
I'm trying to do a simple thing. display an image texture, using a perspective projection type.
I other things in mind after that but I want to start with something like this, and I'm already struggling.
I want to be able to plug an image texture to my OSL texture node. To be able to display my image, I need to set its Projection to OSL UV, but I want to force the OSL Texture node to display it with the Perspective mode.
And in the mean time, be able to control the value of the Perspective Projection.
I had a look at the documentation:
https://docs.otoy.com/osl/input%20types/
But I'm a bit confused about how to use the information gave here.
"To specify a default projection type for projection input, use "projection:<type>"."
I will be very grateful if someone can enlighten me about that!
OSL Texture and Projection Question
Hi Tenart,
please, have a look at this discussion about OSC Camera Projection node with examples, from Calus:
viewtopic.php?f=21&t=65575&p=331877&hil ... ve#p331877
ciao Beppe
ciao Beppe
Thank you Bege, it was very help to see how to manipulate the projection.
Another question would be, how to manipulate the value inside of a point, projection type of node.
For instance I'm using this line to declare my projection.
But I want to force it to have specific values ( in my case, I want to change the Translation values)
Sorry for my lack of knowledge and thanks for your help ^^
point Vector = P [[string label = "Projection",string inputType = "projection:perspective"]],But I want to force it to have specific values ( in my case, I want to change the Translation values)
Hi Renart,
since I don't know exactly what you want to obtain, I have modified the script from Calus, adding a Move X and Y input:
ciao Beppe
shader OslCameraProjectionMove(
float mx = 0 [[ string label = "Move X"]],
float my = 0 [[ string label = "Move Y"]],
output point uvw = 0)
float setRange( float f)
return 0.5 * (1.0 + f);
vector cameraProj(vector p)
float fov;
float pa;
float scale;
int res[2];
vector st;
getattribute("camera:fov", fov); //fov is already in radians
getattribute("camera:pixelaspect", pa);
getattribute("camera:resolution", res);
float ar = pa * res[1] / res[0];
scale = 2/tan(fov/2);
st[0] = setRange(p[0]/-p[2]*ar*scale)+mx;
st[1] = setRange(p[1]/-p[2]*scale)+my;
return st;
vector PP = transform("camera", P);
PP = vector(PP[0], PP[1], PP[2]);
uvw = cameraProj(PP);
}Grazie mile Beppe.
Not exactly what I was thinking tho. I was talking about in general, when I create a projection using OSL, how to change its transform values.
Like when I create an Integer or float input I can specify its default values and use them/access them, easily in my functions.
Is it related to the delayed evaluation?
Thanks for your help!
