OctaneRender® for 3ds max® v3.08 RC4 - 5.05 [OBSOLETE]
coilbook
neonZorglub wrote:Hi coilbook,
Thanks for reporting the issue with PhoenixFD. There is indeed a bug in the volume rendering.
That also affect the Octane Volume objects, using VDB files.
A temporary work-around is to add a render pass, for example, add a Diffuse pass in Render settings / Render Element ..
A fix is being working on for the next release.
Thank you Could you also check particles like foam, splash and dark ocean after the grid border to make sure they render correctly
justix
Render restart on opening of the Material Slot while rendering???
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
paride4331
Hi coilbook,
try with RC4, you should solve it.
DartFrog
So, clarify something for me. Are there two teams working on 3dsmax plugins now? One for 3.08x and one for 4.0x?
I know that my workflow won't be dramatically improved by these incremental 3.0 plugin updates and thats fine, that's just me. But why not focus all resources on getting plugins for 4 up and running and abandon 3?
paride4331
DartFrog wrote:So, clarify something for me. Are there two teams working on 3dsmax plugins now? One for 3.08x and one for 4.0x?
No there aren't. Octane V4 is under development, new V4 XB2 will be 3.08 RCx + V4. I do not think a stable version will be released soon.
I think Octane V4 XBx for 3dsMax test version will be released in the near future.
coilbook
Hi I am not sure if I asked this before but now when my octane viewport is opened one of the slaves quits working and then I open network I see a duplicate of this slave with a different IP. Thanks
Elvissuperstar007
Sheen not work
paride4331
Elvissuperstar007 wrote:Sheen not work
paride4331
coilbook wrote:Hi I am not sure if I asked this before but now when my octane viewport is opened one of the slaves quits working and then I open network I see a duplicate of this slave with a different IP. Thanks
Hi coilbook,
are you using a hub switch in your network or is it connected to something like a router? I had this issue in the past, but not using hub switches.
Has it happened since you use windows 10 and windows 7 together?
coilbook
Hi coilbook,
Hi Paride
all PCs now have windows 10. Master and one of the slaves are connected to the router. Then there is a 50 foot cat7 cable that goes from the router to the switch. Three more slaves are connected to that switch (dlink switch). One of the slaves that connected to the switch is doing this.
Return to “Releases”
