OctaneRender 3 for Rhino (OBSOLETE)
Why is my node window so small??
when i mouse over the small window ans scroll, i can scroll all the parameter, but i can only see 1 line at a time.
It's a bit hard to help if you don't indicate if you are using Rhino5 or Rhino6. However it looks like maybe your Windows font is set to something which it effecting the panel layout.
tomo8177
i was running Rhino 6 on Windows 10.
this wasn't happening when i was using Rhino 5.
Changing the Windows Font didn't solve the problem for me...
What is your screen resolution set to pls? Are there any other Rhino panels which as not displaying correctly?
tomo8177
i am working with a laptop with 3840 x 2160 resolution, 64 bit Windows 10 machine.
with 200% text scale set by windows.
all other Rhino panels look fine.
the Octane setting panel looks okay, by the way.
Thanks. I will see if McNeel are able to help with this.
franchais
Hi Paul,
This tab keeps popping up when the live viewport is open.
K
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
This is fixed in the next release of the plugin (which I will try to get out in the next day or two).
franchais
Great thanks paul
franchais
Any updates on the next release?
RizonParein
Tried to install the plug in for a fresh installed Rhino 6 (latest version).
Tried the two last plug in versions, same error
Return to “Rhinoceros 3D”
