Suggestion needed for Render job graph
calus
abstrax wrote: The render job graph is just a Lua script graph sitting on top of the render job graph Lua API, allowing everyone to write his/her own render job implementation. Lua scripts can't create an arbitrary GUI in the node stack editor, but only input linkers, i.e. what you are asking for is currently not possible.
Oh, I see.
And right, be able to make its own render job version is a very nice/important feature.
abstrax wrote: What is wrong with the setting the render target count for the batch render job graph anyway?
This is just less intuitive/usual than the add/remove button.
Else, an even better way to do this,
is to automatically add/remove an empty linker pin each time a target is plugged/unplugged (there's always only 1 empty pin).
This way no need to use the node inspector at all for that.
Pascal ANDRE
gah5118
not sure if this was addressed, about to test the latest octane release; however, the frame range will default to the last available frame when you reopen the scene. So, each time opening the scene, you have to remember to go through and reset all of your batch render nodes.
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
vijay
gah5118 wrote:not sure if this was addressed, about to test the latest octane release; however, the frame range will default to the last available frame when you reopen the scene. So, each time opening the scene, you have to remember to go through and reset all of your batch render nodes.
Noted down. will try to fix it in upcoming release.
gah5118
another issue I discovered, is if you have 1 frame setup (frame range 2-2 for example), when starting the batch render, it will say finished. There has been quite a few cases in the past week that I needed to do this due to different circumstances.
vijay
gah5118 wrote:Thanks!
Thanks. I noticed it as well. Will be fixed in upcoming release.
Vijay
manalokos
Batch render job doesn't compile correctly or render correctly, sometimes it doesn't render at all, other times sabes the current render, but usually it renders the cameras but with geometry missing.
It would be a wonderful tool if it worked.
Kind regards
Filipe
Tazan
vijay_thirukonda wrote: You can render different render targets with a different animation frame range in a single go/button.
Hi and sorry for doing a revival of this thread, but it's been days I'm tring to figure this out: how is it possible to render different render targets with a different animation frame range with this Batch render job node, please?
vijay
You will need multiple batch render jobs nodes for setting different time frames. Then you can connect all batch render job nodes to a render job group node and start the group job.
Tazan
Ok that's the kind of solution I've concluded :) Thanks a lot for your response Vijay!
Best.
Tazan
Hi Vijay,
I have yet another question on the Render job: at the moment when I put the frame ranges for each renders, it won't keep them in memory whenever I close the window.
Which is a bit annoying for small lists, but can be very annoying for big lists like the one in the following picture:
Also, I don't know Lua script language but is there a way to assign a frame range for each Batch render job by their name?
Best regards :)
