best settings for 1080TI? :D
gsfcreator
just got my new pc! *excited*
are there any recommendations I should tweak in Octane to get the maximum speed for my renders? (Increasing bucket size, etc? )
core 8700K, 32RAM, GTX1080TI
thanks <3
here is a screenshot of the bottom viewport screen. I don't think I'm exploiting the full potential of this GPU:
Core I7-8700K, 32RAM, GTX1080Ti, win10
wimvdb
I used these settings:
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
gsfcreator
wimvdb wrote:I used these settings:
thanks yet again, Wimvdb! :)
gsfcreator
The attachment renderfast.png is no longer available
strange. I rendered after changing the settings to match yours, and I get this cartoonish-like result:
any idea why?
*update*
changing the coherent ratio to 1.0 caused this. when I put it back to the default it renders normally. but its cool to know I can create toon-like rendering with this tweak :O.
wimvdb
Coherent mode needs at least 500 samples (it starts very noisy).
You could also try to increase the max tile size to 32. That may render faster as well.
gsfcreator
wimvdb wrote:Coherent mode needs at least 500 samples (it starts very noisy).
testing. I see that even when I render a scene in high res, it barely uses 1-1.5 gigabyte tops from the GPU. any way to use more memory and render faster?
If you have a look at the link in my signature, there is a suggest for the GI Clamp which will reduce firefly's and therefore decrease render time.
gsfcreator
face_off wrote:If you have a look at the link in my signature, there is a suggest for the GI Clamp which will reduce firefly's and therefore decrease render time.
Hey there, paul. thanks! I'm looking into your suggestions. a question:
2) Increase Kernel->Caustic Blur (to smooth out Specular and Glossy material highlight noise) ---> how much? I'm set at 0.01 (default) and my renders in octane 7500 samples that take 2 hours looks noisier than a firefly render on 1 minute, at the moment (I'll post a separate topic with images only after I'll try everything that you guys are suggesting, cause I feel that this is a render specs + lighting issue. Octane treat lights differently, it seems.)
The link in my signature provides help and a range of options for minimising noise. Caustic blur won't help if GI Clamp is at it default value and your lights are not setup right. So start with GI Clamp = 10 and work from there following the suggestions in my signature.
Return to “Poser”
