OctaneRender™ Standalone 3.08 RC 4
abstrax
Hi all,
This is the fourth and most likely the last release candidate of 3.08. Beside various bug fixes, we made some significant changes in network rendering communication and would like to have it checked by a few people before we call it a stable version.
For an overview of all new features of 3.08, please read the new features thread.
As noted before, we are now using CUDA toolkit 9.1 (to allow for Volta support) on Windows and Linux, which requires NVIDIA drivers of version 387 or higher.
Due to issues with the current CUDA drivers for Mac we are using only CUDA toolkit 8.0 on OSX, which is why any CUDA driver for Mac should work that supports CUDA 8.0 or higher.
Changes since version 3.08 RC 3:
  • Added a separate roughness channel for sheen.
  • Fixed sampling of the backside of glossy materials.
  • Fixed the 90° falloff mode of the falloff node.
  • Fixed possible kernel crash when rendering scattering media.
  • Fixed incorrect handling of grid offsets and coordinate system handedness of volume nodes.
  • Fixed incorrect handling of materials with an IOR < 1.
  • Various changes to make network rendering communication more robust:
    • Added heartbeat to the net render master and daemon connection to allow both sides to figure out, if the connection has died for some reason and then close it properly. We had to bump up the internal daemon message version number which causes the net render master to ignore any daemons of a previous version.
    • Fixed an issue where a net render slave with failed GPUs got work assigned by the master, which didn't get reassigned to other slaves/GPUs if the work assignment was done after a render restart after the GPUs failed on the slave.
    • Added a slave recovery to the net render daemon, which tries to restart a net render slave up to 4 times if the slave crashed or failed.
  • Added refresh button to the scene outliner which allows you to update the local DB content.
  • Tried to improve the texture node drop down menu.
  • You can now select more files in the animated image file dialog and fixed the behaviour of the clear button.
  • Fixed bug prohibiting you sometimes from rendering a thumbnail, because it can't find a node suitable for preview rendering.
Downloads for users with a regular license
regular version for Windows (installer)
regular version for Windows (ZIP archive)
regular version for Mac OS X (DMG image)
regular version for Linux (ZIP archive)
Downloads for users with a subscription license
subscription version for Windows (installer)
subscription version for Windows (ZIP archive)
subscription version for Mac OS X (DMG image)
subscription version for Linux (ZIP archive)
Happy rendering,
Your OTOY NZ Team
3dworks
great to see the progress. has the shader ball issue on OSX (causing hangs with lightwave) been fixed as well?
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
PolderAnimation
'Tried to improve the texture node drop down menu.'
I think it is better. Less submenu's are nice!
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
funk
Thanks for separating sheen roughness :)
I'm noticing that you get artifacts if you have a low glossy material roughness, along with sheen/sheen roughness though.
In this example, you see a circular pattern in the glossy material
EDIT: It also appears in the metallic material
sheen_metallic_roughness_artifacts.orbx
(446.61 KiB) Downloaded 473 times
sheen_glossy_roughness_artifacts.orbx
(446.22 KiB) Downloaded 452 times
roeland
funk wrote:Thanks for separating sheen roughness :)
Thanks for reporting, I'll look into it.
coilbook
can we have OSL shader library in octane or at least one dedicated thread where all OSL shaders can be uploaded. There are so many cool new shaders I accidentally found around this forum would be nice to keep them in one place Thanks
stefano-dear
I have some problems with Daemon on my 2x GTX 980 Ti.
Win10 with 388.13 NVIDIA driver
OctaneRender 3.08 RC 4 (3080013)
Launching net render slave (3080013) with master 10.39.12.184:1025
CUDA error 999 on device 2: unknown error
-> failed to bind device to current thread
device 2: failed to initialize context
CUDA error 201 on device 2: invalid device context
-> failed to create link
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
CUDA error 999 on device 3: unknown error
device 3: failed to initialize context
CUDA error 201 on device 3: invalid device context
device 3: failed to create OSL compile context:
device 3: failed to compile module 0
No problems with the other two GTX 1080 Ti...
Stefano
dyrdee
Hi Stefano,
There are new requirements:
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
aufwind
can someone 'enlighten' me, how to rotate an assymetrical ies light correctly (with 3.08)?
In 3.07 it would work with an transform node (translation 0-1) without any projection node attached.
As of 3.08 this approach doesn't work any more.
Edit: By adding a Mesh UV Projection Node the Look of 3.07 and 3.08 is the same. Still leaving the question if this is the right approach for rotating ies textures?
Thanks.
3.07
3.08
ies
Bega_Langfeldleuchten.orbx
(96.76 KiB) Downloaded 460 times
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
abstrax
aufwind wrote:Hi,
Thanks.
Thanks for the report. The issue should be fixed with the stable 3.08 release.
