Volume node setting issue
There has issue in the volume node setting, i have two volume node both reading the same VDB files.
Once i change the volume setting in one of the node , then the other node will also change , but i have to set it different volume setting in different node, that i can loading different volume in the same VDB file.
Is this some kind a issue or limitation in volume node ?
