Version 3.08-RC3
MRoz
Hi Ahmet,
Since Release 3.08-RC1.1 I experienced weird things with PMC mode.
All my materials becomes white, lighting works but materials aren't.
I thought it was because my materials were created in an older version but it seems that it's the same with new ones and fresh scene.
Release 3.08test6.1 is working fine for me though.
Thank you,
Maxime
bododge
Studio21 wrote:@ WG I would want that to but its up to Insydium to make it possible in their SDK. RN its only allowed in Cycles4D
I hadn't heard this was the case..How do you know that?
momade
Dear aoktar and dear community.
Maybe I am doing something wrong. How can I limit the colors of the gradient node to straight colors without interpolation? Setting the interpolation to "None" does not work. Octane still interpolates between the nodes.
momade wrote:Dear aoktar and dear community.
You should use "interpolation" on top not c4d's parameter.
bobbyrtaylor
I'm using 2 nVidia Quadro 5000 while I have the latest driver version for this Card (v377.83) nVidia will not allow me to use (v391.xx) however c4doctane v3.08-test6 works just file with nVidia Quadro 5000 (v377.83) Driver.
Windows 7 x64bit ] Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz ] 8GB Memory ] 2-nVidia Quadro FX-3700 ]
fleshs
The attachment Capture.PNG is no longer available
solution option
solution option
2018-04-03 00.45.20.png (3.71 KiB) Viewed 5161 times
Wrong usage! Why don't you just use this? Invisible option?
stefano-dear
I have tried this release but is very slow on my Mac on C4D R19.053 - CUDA Driver Version: 387.178 - NVIDIA Web driver 378.05.05.25f06
I don't know the why... :roll:
And crash frequently:
_BugReport.txt
(378.37 KiB) Downloaded 337 times
EDIT
The problem is caused by the "Camera Imager", when it is disabled everything works correctly!
fleshs
:roll: Thanks!
miohn
stefano-dear wrote:I have tried this release but is very slow on my Mac on C4D R19.053 - CUDA Driver Version: 387.178 - NVIDIA Web driver 378.05.05.25f06
_BugReport.txt
EDIT
I reported the problem with the "Camera Imager" weeks ago!
Working still with Version 3.07
regards
Mike
Return to “Releases”
