C4d glitches regularly while working with LV
crackfox
here is a recent problem i started to have.
while moving around some objects, cinema flips out, becomes unresponsive and i have to reset it. happens daily 10 times.
screencap below.
crackfox
fwiw octane is version 3.07 -r2
c4d r18
the ui dissappears and viewport elements start appeareing and disappearing.
i am also using a 3d mouse when this is happening, not sure if related.
Do you see cuda errors in Console window or octane log window?
crackfox
hi,
when the glitch happens i cannot interact with c4d. maybe i can have the console open and make a screenshot when this occurs.
crackfox wrote:hi,
Yes pls work with console open and visible and check for any errors. Also try different drivers.
