Version 3.08-RC1.1
Clunkid
I was testing the toon shader and encountered this situation on low poly models, the secondary shadow seems like is not using phong while the primary seems to work fine.
I don't know if it is something wrong with my setup but I couldn't find a workaround.
Phong angle: 40
Phong angle: 0
zinogino
Is it possible to rework the lock resolution settings on the IPR?
It still rescales whenever the Restart New Scene is pressed
Would be great if we have a new lock resolution setting sorta like what Arnold or Redshift3D is having.
VVG
Ahmet,
it`s limtation UberMat (not connect "standart" mat)?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
and i send for you
BUG
with volumetric update in LV
(for fix need update density value or any sliders)
VVG wrote:Ahmet,
Limitation is not a correct word for me. It's designed to work with special node(sub-material). It's not a material in reality, it's a texture type. But will be threated like a octane material.
zinogino wrote:Is it possible to rework the lock resolution settings on the IPR?
Well i know it, but thanks for reminding that. We have a lock res scaling in LV, isn't? It's a problem like reseting zoom level of LV to 1.0 after reopen LV.
Kalua wrote:So far I found this release solid rock!
I'm still finding inconsitency issues among the shaders preview windows resizing: they behave differently along MIX, Uber, Metal, Diffuse, Toon, etc. concerning pixelation, sphere framing, stretching, sometimes is pixelated, sometimes are ok... I found the MIX material to be the only to nicely previewed in every aspect mentioned.... the others beahave randomly well...
I'm uploading this small .gif, perhaps it may help improving this, Aoktar!
Cheers!
I'll look to this but no promise to fix those. Because they are a side effect of new speed improvements of material previews. Do you wish to get back preview lags?
Kalua
Cheers!
Overall it feels better, Aoktar... I wouldnt bother to stay with new system, its a lot faster and it's pitfalls are bypassable.
Great work overall!!!
Cheers!!
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
zinogino
Yup it still zooms whenever it reopens the IPR. Thanks !
Kalua wrote:
Cheers!!
I'll try to fix, thanks for bring that and giving feedback for performance.
Return to “Releases”
