OctaneRender 3 for Rhino (OBSOLETE)
I have updated the Rhino5 installer for release 3.08.0.88, due to the previous version writing debug messages to the Octane Log. Pls update if you have previously installed this version.
v-cube
I am sorry, but It still dont work here ...
error message:
rhino version:
... i will try a complete uninstall first and give it another try...
best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
I just did a test install into Rhino5 SR12, and it worked fine.
The error is saying that Rhino5 cannot find Compat.exe, which indicates a Rhino installation problem.
v-cube
strange...
I installed my new rhino 6 and 7
Interestingly the r6 version of the plugin installed without problems...
I am running the latest rhino SR 14 here...
I will try it on another machine...
best
Andreas
I am quite confused by your comments. There is no OctaneRender for Rhino plugin for Rhino7.
v-cube
Ok, i think i was a little bit unclear...
What I meant is that I installed Rhino 6 and the Rhino7 WIP , in this sentence I was only referring to Rhino not octane...
As I said, I will try to install the octane Rhino plugin on another machine tomorrow...
Best
Andreas
I
v-cube
OK, just for the record...
I don't know why , but after successfully installing it on another machine, I tried it one more time on my personal workstation, miraculously it worked this time....
so Problem solved...
P.S. the R6 version also runs with the Rhino 7WIP...
best
Andreas
franchais
I've tried the rhino 6 version, but once I open the octane viewport, it gets stuck to what ever view I'm looking at in the rhino viewport. So I'm unable to navigate around.
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
v-cube
yes, it is broken right now... you camn workaround by unlocking the "lock camera " feature in the octane render window, see pic
tomo8177
Why is my node window so small??
when i mouse over the small window ans scroll, i can scroll all the parameter, but i can only see 1 line at a time.
Return to “Rhinoceros 3D”
