Changing Gradient deletes vertex tag (3.08 RC 1.1 and older)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
dinf
changing a gradient to linear/radial deletes not only the connected vertex map node, but the vertex (color) node on the object also.
This is not unduable.
Try the attached test scene and open the material, either in Node Editor or in Cinemas material editor. Change the Gradient to linear or radial and have an eye on the tags of the object plane in the object manager, especially the vertex color tag. It disapears at the same time as the vertex map node when it gets replaced, the material changes in LV and Active Object Manager also shows, that the tag is gone. As said: this is not undoable.
To get there I simply painted the vertex color into the tag, opened a new material in the node editor, made a vertex and a gradient node and linked all together. Then I switched the gradient for mistake. One can start the LV to see the changes there as well.
Please tell me if you need more info to reproduce as well.
Hope it helps, and thanks.
vertexcolormap-test.zip
(98.84 KiB) Downloaded 199 times
This is tested with R19.053 + Octane 3.08 RC11 and R18.057 + Octane 3.06.2,
Win 10 Pro, GTX 1080, 4K monitor, 96 GB RAM, Nvidia 388.71*. Standalone 3.08 RC 1
and also by some other C4D users with different machines.
No response in the log window.
*391 also, but it is a mess to install this with win 10.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
Thanks for reporting this! That's not a bug because operation which is designed in purpose. It will create a sinewave texture and connected nodes and delete previous connection. Only thing i can do that adding a UNDO operation.
dinf
aoktar wrote:Thanks for reporting this! That's not a bug because operation which is designed in purpose. It will create a sinewave texture and connected nodes and delete previous connection. Only thing i can do that adding a UNDO operation.
Thanks for fast answering Ahmet!
I do understand that it is creating new nodes and deletes the previous ones.
But what is also happening, it is also deleting the TAG of the object with the originally painted color information, wich is connected to this node.
Ok i see! Added exception for deleting tags in this command.
Return to “Bug Reports”
