2018 crash when using open vdb files
Bugstomper
Hello,
I was wondering if this is an Octane bug or if I'm doing something wrong.
Start from an empty scene and switch to perspective view. Add a null, in object properties add an Octane Volumetrics, load a vdb file. Switch to camera view using the keypad shortcut. At this point layout crashes every time.
linograndi
Confirmed. Definitely something to fix.
juanjgon
Yes, I can reproduce this problem here. Investigating ...
juanjgon
This problem is related to what I think is a bug in LW 2018. I've reported it to the LW developers to investigate it, but fortunately a workaround on the plugin side is easy to add, so in any case, this problem will be fixed in the next Octane plugin build.
Bugstomper
Good to hear Juanjgon, thanks! :)
Return to “Lightwave 3D”
