LocalDB Problem
BorderLine
Hi JuanJo !
Don't know what's happen ! Indicate local path of LocalDb in Octane plugin option but importing texture doesn't work !
Intenet ok !
Any idea please ?
BorderLine
I indicate E:// LOCALDB and apparently, jpg are downloading in my images / works folder !
juanjgon
Yes, this how it works by design to make the material textures relative to your project.
The plugin localdb folder parameter is there to specify the Standalone localdb database location to make possible interchange materials between the two applications, but when you import a livedb/localdb material, the textures are expanded into the project images folder.
BorderLine
Hi JuanJo !
Ok, picture download in local images folder ! It's work !
But the picture is not read in the texture and does not appear in the texture when I edit it !
Any idea ?
juanjgon
Do you have an UV map created in the object? Usually, all the liveDB materials are designed to work with UV maps.
BorderLine
Yes, i've UVMap ! Picture downloaded, it's OK but when i edit texture, th bitmap isn't loaded ! If i click to load picture, folder opens and load the first bitmap indicated but if i trying to load another bitmap, nothing happen !
Can you try please ?
Thnaks
juanjgon
What material are you downloading?
juanjgon
I'm testing the LiveDB feature, and the materials and textures seem fine here ...
Return to “Lightwave 3D”
