Have to say, Otoy's response to this issue has been woefully inadequate.
Essentially their solution is 'don't use fall edition'
Un-believable.
Paride, can you get any more information or explain to Otoy that 'don't use fall edition' is not practical
Something like this should have prompted an email from Otoy to all the users, instead we get this;
viewtopic.php?f=30&t=64358&p=329466#p329466
OctaneRender® for 3ds max® v3.07 - 4.44 [OBSOLETE]
- paride4331
Hi guys,
I think it does not depend on Octane, it depends on windows10. I tried using Multi GPUs with windows10 without using Octane and I've found issue anyway,
with drivers with video games etc, it seems that Windows10 does not want to support Multi GPUs,
if you search on the internet, you will find many topics about this issue.
- Elvissuperstar007
- Contact:
Started logging on 08.02.18 23:35:49
OctaneRender 3.07 (3070007)
Another instance of Octane is currently performing authentication tasks
- paride4331
Hi Elvissuperstar007,Elvissuperstar007 wrote:Started logging on 08.02.18 23:35:49
The error Another instance of Octane is currently performing authentication tasks is shown when there is more than one instance of Octane running and performing license activation / deactivation. If you receive this error, ensure that only one instance of OctaneRender Standalone, Octane plugin, or OctaneRender Slave Daemon is running on the machine. In rare cases the lock used to detect this state may become invalid due to a crash or invalid state in the Octane plugin application. If this is the case, you may need to sign-out or restart before you will be able to release licenses.
paride4331 wrote:Hi guys,
Hi Paridie,
and by multi gpu do you mean rendering using slaves connected or having many gpus in one PC?
Our master has 3 GPUs and they work fine at the same time, problem is after 2-3 hours all network slaves quit rendering like they are not there even though they are showing OK in octane network list. So constantly have to open octane network window and recheck slaves.
How should I start trouble shooting this problem? Is there any real time network monitoring. It looks like problem is related more towards network than GPU
thanks
- paride4331
Hi coilbook,
I'm not sure every issue is about windows10 and last update, I have no technical data, my idea comes from issue that some many multi GPUs users have encountered problems after this update.
About your network issue, you could post your slave and master flag. It could be useful to better understand what happens.
viewtopic.php?f=27&t=62388&p=318853&hil ... on#p318853
- Elvissuperstar007
- Contact:
I give you a unique scene! everything was created by me. why the animation render stops, there is enough memory
3ds max 2016
Laubwerk 1-2-3
Octane Render 3,07-44
https://cloud.mail.ru/public/NAUd/W9PPai1xi
3x 1080 ti Win 10 390.77
Please correct the buffer filling
the render is frozen
I give you the right to use the scene for testing
3ds max 2016
Laubwerk 1-2-3
- Elvissuperstar007
- Contact:
why the camera MB is not disconnected! how can I remove it! exports to ORBX did not help
we do not need this scene MB
- CAMERA.rar
- (332.89 KiB) Downloaded 256 times
- bandicam 2018-02-10 12-32-02-100.mp4
- (2.22 MiB) Downloaded 4504 times
- images.png (4.8 KiB) Viewed 5257 times
- Elvissuperstar007
- Contact:
every second frame stops!
memory is enough, exports to ORBX The render works but there can not be disabled MB
I uploaded you a video
scene loaded in the last post
1frame 7.784 Gb -next 2 frame 8.459 Gb -next 3 frame 7.784 Gb -next 4 frame 8.459 Gb ....... -next frame
I had to render each frame through a dynamic viewport! Make it possible to render the animation
- bandicam 2018-02-11 11-53-28-681.mp4
- VIDEO BUG
- (34.1 MiB) Downloaded 4480 times
