What is the "proper" way?
I know that there is something called LocalDB, but how to use it?
Or maybe there is a better way?
The best way to manage Octane materials for later reuse?
MODO 902 SP1 + Octane 3.0.4 | Windows 10 64bit, i7 4790K, 32GB | 2 x Asus Strix GeForce GTX970 4GB
[url=be.net/JakubRupa/]Behance[/url]
If you want to reuse materials always inside Houdini, the best solution is to build HDAs with the Octane VOP nodes that you need to build the material embedded inside. The important parameters needed to control de material can be exposed in the top HDA node, and these nodes can be used over multiple projects from a source library.
http://www.sidefx.com/docs/houdini/assets/index.html
Hope this helps,
Hope this helps,
Thanks, Juanjgon.
It is possible maybe to save textures inside HDAs to use with Octane?
Yes, you can include texture maps inside the HDAs. This is a brief introduction about how to work with them:
https://dimitriscg.wordpress.com/2016/1 ... s-in-hdas/
That's great, thanks Juanjgon!
