Authentication error
Unity Integrated Plugin (Integrated Plugin maintained by OTOY)
Moderator: ChrisHekman
Olivier31
Hello
I have a problem when I want to do "Load Octane", it shows me this error:
Authentication error: The timeout date has passed (0x24412754)
UnityEngine.Debug:LogError(Object)
OctaneUnity.PluginController:LogErrorCallback(String)
System.Object:wrapper_native_00007FFEFFC14310(Boolean)
Octane.DLL:Api_Init(Boolean)
Octane.Api:Init(Boolean)
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
So, can not use Octane
I made the last update of Octane Render, and I am working on the Unity version 2017.1.0F3.
Thank you !
REOVIZ
Hello,
I have the same problem with Unity2017.3.0p3.
The octane plugin can't load because of that error.
I tried to log out and login again but no change, the authentication error is always here.
pfaith
On the unity forum, somone sugested going to the octane settings (is a top level menu in unity, the click on version control, then go one level back. This worked for me, in that rebooting and or anything else I wasn't getting the load. So I am now 2017.3 unity with version 1.1.0.1207 . I btw wasn't seeing any error, the problem was that octane just wasn't loading when i clicked on the load button.
ahrenm
Ditto.
No Octane for me today. Tried to uninstall and re-install the plugin, no joy.
I think your auth server is unhappy.
A.
ChrisHekman
We are working on fixing this issue.
ChrisHekman
This issue has been fixed in the new build. You can upgrade via the octane -> settings window.
Return to “Unity”
