Modo Octane Render Queue
Have you tried to use modo render passes groups?
I found it's very useful.
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
If you are handy with Modo python you could write something to do this. Or export each lxo to orbx and render using an Octane Standalone render queue LUA script.
- Hesekiel2517
Dmi3ryd mentioned Render Passes Groups. Is it possible to set up different Render Passes in Modo and Render them with Octane? That would help a lot since I have to render a lot of variations of a scene.
Sorry - I don't completely understand what you are trying to do here. If you are rendering an animation, you can tick the Kernel->Animation->Export Render Passes as Discrete Files to save each render pass in a separate file each frame.Dmi3ryd mentioned Render Passes Groups. Is it possible to set up different Render Passes in Modo and Render them with Octane? That would help a lot since I have to render a lot of variations of a scene.
- Hesekiel2517
No
Modo has a function to setup different scene states as Render Passes:
For Example:
Pass 1:
Mesh 1
Material 1
Pass 2:
Mesh 1
Material 2
Pass 3:
Mesh 2
Material 1
Then you can hit Render Passes and Modo will automatically render each of these settings. When I read Dmi3ryds post i thought it is somehow possible with octane. Is it?
https://help.thefoundry.co.uk/modo/cont ... asses.html
https://www.youtube.com/watch?v=_5Uz7NGNVTY
For Example:
Pass 1:
Mesh 1
Material 1
Pass 2:
Mesh 1
Material 2
Pass 3:
Mesh 2
Material 1
Sorry - I am not sure if this is possible or not.When I read Dmi3ryds post i thought it is somehow possible with octane. Is it?
