Is the tracker broken?
Whispermode
I'm seeing some really strange behaviour in the tracker in the latest release.
Are there any known issues?
A couple of things to note:
1. If I delete a single track point that's causing a problem with the solve error average (i.e. 'Average Error 1.1234'), it makes everything a lot worse. Track points with a good solve error 0.2, 0.3 etc. jump up to random large numbers like 83.1, 45.8 etc.
2. The overall solution solve error changes dramatically every time I click 'Solve Camera Motion'. 35.1, 65,7 etc.
The same footage using the same trackpoints doesn't cause the same problem in the latest release of Blender on the Blender site using Cycles.
Any ideas? Thanks in advance.
azen
Thank you for the detailed report. While we await the resolution for 3.08, we are still actively testing and developing for Blender - we will investigate this issue further.
Cheers,
Azen
Whispermode
azen wrote:Hi,
Cheers,
Azen
Thank you, Azen.
I broke the video down into separate PNGs, then created and opened as an image sequence. This seems to have solved the problem but it's definitely a change in behaviour since the last version.
Cheers.
Return to “Blender”
