disabled windows firewall, now get the error below when loading octane in unity. also when running the installer install_t1.exe, fails installing, "no compatible unity installation were found, 2017.3.0.63597
so i'm thinking this version is not compatible with the latest build of unity??
IndexOutOfRangeException: Array index is out of range.
OctaneUnity.Upgrader.FixMissingDLLs ()
OctaneUnity.PluginController.Init ()
OctaneUnity.PreferenceWindow.OnGUI ()
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:222)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:232)
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MethodBase.cs:115)
UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:295)
UnityEditor.HostView.Invoke (System.String methodName) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:288)
UnityEditor.HostView.InvokeOnGUI (Rect onGUIPosition) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:255)
1.1.0.1223
Moderator: ChrisHekman
- ChrisHekman
Do you still get the server handshake error?r1kbogusz wrote:disabled windows firewall, now get the error below when loading octane in unity. also when running the installer install_t1.exe, fails installing, "no compatible unity installation were found, 2017.3.0.63597
Also what version of unity and Octane for Unity are you using?
I don't think so, I'll have time later today to work on this.
Unity is build 2017.3.0f3. i downloaded the octane for unity install_t1.exe and it fails to install, error "no compatible unity installations were found, 2013.3.0.63597
- ChrisHekman
Could you try to use installer scene from the asset store?r1kbogusz wrote:Do you still get the server handshake error?
https://assetstore.unity.com/packages/3 ... ene-105646
ChrisHekman wrote:Could you try to use installer scene from the asset store?r1kbogusz wrote:Do you still get the server handshake error?
ok, found a little time today to try this again, did make some progress and successfully installed octane for unity, accounts linked, and now get this new error
Authentication error: The host application is not signed by 'Unity Technologies SF' (0x167F0E80)
UnityEngine.Debug:LogError(Object)
OctaneUnity.PluginController:LogErrorCallback(String)
System.Object:wrapper_native_00007FFDE0004310(Boolean)
Octane.DLL:Api_Init(Boolean)
Octane.Api:Init(Boolean)
OctaneUnity.PluginController:Init()
OctaneUnity.OctaneUtility:LoadOctaneButton()
OctaneUnity.PBRRenderTargetComponentEditor:OnInspectorGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
- TankThunderbird
I can't load Octane with this version anymore, I had to go back to version 1207 to get it to work again, but I get many errors even though it kind of works.
I am using the Docking Bay scene with unity 2017.3.0f3 and Octane was working perfectly until now.
My original error in 1223:
Authentication error: The timeout date has passed (0x24412754)
System.Object:wrapper_native_00007FFDBA954310(Boolean)
OctaneUnity.<>c:<GetTierDataFromServer>b__29_0(AuthCodeResponse)
UnityEditor.AsyncHTTPClient:Done(State, Int32)
All errors in 1207:
Octane settings version number mismatch. Found 2, should be 1
UnityEngine.Debug:LogErrorFormat(String, Object[])
OctaneUnity.AutoNode:Load(Stream)
OctaneUnity.Manager:LoadNode(Node, Byte[])
OctaneUnity.PBRRenderTargetComponent:Load()
OctaneUnity.PBRRenderTargetComponent:InternalUpdate()
OctaneUnity.Scene:UpdateRenderTargetComponent(PBRRenderTargetComponent, RenderTarget)
OctaneUnity.ObjectLink`2:Update(HashSet`1, Boolean)
OctaneUnity.Scene:UpdateRenderTargetComponents()
OctaneUnity.Scene:UpdateScene(Boolean)
OctaneUnity.PluginController:UpdateInternal()
OctaneUnity.UpperManagement:Update()
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()
Failed loading rendertarget settings for Thin lens camera
UnityEngine.Debug:LogWarningFormat(String, Object[])
Failed loading rendertarget settings for Daylight environment
Failed loading rendertarget settings for Film settings
Failed loading rendertarget settings for Animation settings
Failed loading rendertarget settings for Direct lighting kernel
Failed loading rendertarget settings for Render layer
Failed loading rendertarget settings for Render passes
Failed loading rendertarget settings for Camera imager
Failed loading rendertarget settings for Post processing
Overriding existing asset with new GUID from package, this may break links within your project to package assets (Assets/Plugins/Octane/OctaneBaking.shader)
Assembly: 'C:/Users/Bonham/Repositories/Unity/New Unity Project/Assets/Plugins/Octane/Editor.dll' uses obsolete Unity API (UnityUpgradable)
Tank
Unity 2017.3.0f3
GeForce GTX 980 Ti
Intel Core i7-6700K CPU @4.00 GHz
32 GB RAM
Windows 10 Pro Version 1709 OS Build 16299.192
All errors in 1207:
Tank
Unity 2017.3.0f3
GeForce GTX 980 Ti
32 GB RAM
- ChrisHekman
We are working on the issue. Apparently a timeout switch was incorrectly set.TankThunderbird wrote:I can't load Octane with this version anymore, I had to go back to version 1207 to get it to work again, but I get many errors even though it kind of works.
Downgrading your project is not adviced as it will have unpredictable outcomes.
- TankThunderbird
Got it.
I am still on the previous version. Just testing out the plugin, so no major danger to production files done. Also, after a restart of Unity, I am no longer getting all the 1217 errors. Will keep testing on this version until your fix comes out, but thanks for the warning.
Tank
Tank
- ChrisHekman
We fixed the issue in the new build. You should be able to upgrade.TankThunderbird wrote:Got it.
Tank
