I havent tried it to see what works, but i fear that a lot of things can go wrong when using plugins like tfd and xparticles or imported stuff from houdini or other alembics, and while its working inside the software, it wont interpret properly to format that standalone uses. I m exchanging stuff a lot between softwares with alembics and i try to avoid it as much as possible. In general from my experience all those years, when u got something working as u want it inside ur software, no reason to complicate things further. I d personally feel safe and that i wont go into troubleshooting, only if i could render from inside c4d direct and not from standalone. Direct like, a one button solution as i do it now with network. I connect slaves, render.Goldorak wrote:Other than size, is there anything that isn't working in the export process? One option we could help with is allowing you to run a remote PC on AWS install your own C4D+Octane (that is what the floating licence is for w./ ORC) and then export to ORC from there super fast - assuming that the connection is the bottleneck?thanulee wrote:+1 essential to be able to send my c4d project instead of exporting it to some other format (complex scenes with vdbs/tfd/particles/hair etc)
I d suggest to eliminate the export phase and have slaves per software as in all other renderfarms. Maybe im shortsighted, but i dont see any advantage for using ORC as is, only unessecary steps that will complex the process even more.
Besides that, the connection speed is something inevitable and i dont think its a problem for me at least. Huge files to upload when cached but ok i know this isnt an issue, its just time.
