Hey Ahmet,
I've recently noticed that the right border value of the render region in render settings does not update to 0% if you drag the area off the render area in the live viewer and choose "Get Last Region from LV".
It retains the last value when dragging from inside. Works correctly from the left side.
I'm also wondering if it possible to have the values revert to their previous values when keyframes have not been chosen? Currently they stay as is, which isn't aligned with the way C4D keyframes work.
Thanks again and keep up the hard work!!!!!!!
This is on Win 10 PC with
64GB RAM / 980tis
Octane V 3.03.3-R1
Cinema 4D R17.053 Build RB166656
Render Region Right Border Update
C. RAM Capacity (i.e. 6 GB)
- joeycamacho
Freelance Motion & Graphic Designer
Cinema 4D R19| Win 10 Home 1803 | 4X GTX TitanX 12GB Maxwell | Intel Core i7 5930K 3.5GHz | 48 GB DDR4 -2133 RAM
Thank! I will test it asap. We can fix that if there's a problem.
- joeycamacho
Thanks Ahmet!!!
Was this bug resolved?
I'm on 3.06.2 and there is still the same problem...
Not checked yet on 3.08
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
