Frank,FrankPooleFloating wrote:So I am quite intrigued by the Noiseblocker NB-eLoop Series B12-PS Black Edition, for slapping on my Hybrids (and maybe everywhere else, except front 200mm) when I do the X9... smicha buddy, have you tried these pups yet? If not, anyone else have these (preferably on some rads)? They at least have the appearance of being something pretty damn special. Perhaps even way better than Noiseblocker BlackSilent Pro or Noctua NF-F12...
http://www.blacknoise.com/site/en/produ ... hp?lang=EN
Also, could I hook these right to the fan cable coming off 980Ti Hybrid, or do I need to use some kind of adapter or something? (NB is 4-pin PWM and 980Ti is 3-pin, right?)... I will definitely ultimately get everything on a fan controller, but not right away, unless I absolutely have to.
Yes - you need to have a fan controller to control them on hybrids unless you use 4pin PWM connectors on your motherboard (and the fans you want to go with are PWM). I used Lamptron FC6 with 4 channels, each 20W - then a regular 3 pin fan is enough for manual speed control.
As for fans: I had for tests all NB fans ... and all are great. I always go with PL2 for my builds (simplicity, great mounting sets and price point). For hybrids though get something that spins faster, i.e., 1800 RPM. M12-3, B12-3. I think I like NB-Multiframe-Series more than eLoop (from very close distance I can hear delicate "tick" sound on eLoop). Noise performance is perfect in both. Multiframe have rubber corners. I know Tom Glimps uses them as his favorite.
