Running 3.05.3 on a titan X pascal
Rendering 22+ scenes all using the same objects
but on ONE scene, after frame 8, it crashes consistently
00:01:26 (0086.01) | <> Mem Used/Free/Total: 899 / 9075 / 12288
00:01:26 (0086.01) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 958266 / 0 / 0 / 1058 / 0
00:01:26 (0086.01) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 15 / 3 / 0 / 0
00:01:26 (0086.01) | ... Init rendering ...
00:01:26 (0086.55) | >>> processing image callback
00:01:26 (0086.55) | Reading preview image
00:01:26 (0086.55) | ... Get sampling information
00:01:26 (0086.55) | ... Statistics: 1 of 300 samples, 0 sec, 5.51 Ms/sec
00:01:26 (0086.55) | ... Get buffers resolution
00:01:26 (0086.55) | ... Resolution: 1920 1080
00:01:26 (0086.55) | ... Check compositing
00:01:26 (0086.55) | ... Compositing 0
00:01:26 (0086.55) | ... Reading frame buffer
00:01:26 (0086.57) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.57) * OCTANE API MSG: -> kernel execution failed(report)
00:01:26 (0086.57) * OCTANE API MSG: -> failed to launch kernel(ptBrdf2)
00:01:26 (0086.57) * OCTANE API MSG: device 0: direct light kernel failed
00:01:26 (0086.57) * OCTANE API MSG: device 0: detected an error on render device! trying to recover...
00:01:26 (0086.57) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.57) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.58) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.58) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.58) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.58) * OCTANE API MSG: -> failed to deallocate device array
00:01:26 (0086.59) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.59) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.59) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.59) * OCTANE API MSG: -> failed to deallocate pinned memory
00:01:26 (0086.59) * OCTANE API MSG: -> failed to unregister pinned memory
00:01:26 (0086.59) * OCTANE API MSG: -> failed to unload module
00:01:26 (0086.84) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.84) * OCTANE API MSG: -> failed to bind device to current thread
00:01:26 (0086.84) * OCTANE API MSG: device 0: failed to initialize resources
00:01:26 (0086.84) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:01:27 (0087.75) | Reading preview image successfully
00:01:27 (0087.75) | >>> Refresh preview window
00:01:27 (0087.75) | >>> Refresh preview window done
00:01:27 (0087.75) | ++++++++++++++++++++++
00:01:27 (0087.75) | +++ RENDER FAILURE +++ processing the failure callback
Cuda 700 errors?
Have you tried to render your scene using one of the latest plugin builds (3.07.0.1 or 3.08.0.0)? If it is a bug in the Octane core perhaps it is fixed now. If not, we are going to need the scene to try to reproduce the problem here.
You could try setting your TdrDelay longer. I don't necessarily think that is your issue but it's worth a shot.
Open regedit. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers" and create a key of type "DWORD (32-bit)" and name "TdrDelay" with a decimal value of like 100.
I was getting several cuda 700 and 702 errors and increasing this timeout completely fixed my issue.
