Vray convertion crash max with this file
HHbomb
Hi, I tried to convert this vray material but it crash max...
I don't know why. Any help ?
crash.zip
(21.63 MiB) Downloaded 269 times
paride4331
Hi HHbomb,
I do not know why you crashed, I converted, attached for you.
crash2.zip
(16.01 MiB) Downloaded 244 times
HHbomb
So bad.... I don't know why it crash my max...
justix
HHbomb wrote:So bad.... I don't know why it crash my max...
Often it does on this side too.. check what version of Vray scene you are trying to convert as Octane has an option as legacy compatibility ( 1.9 up to 2.23 vray ) within the converter AND/OR doon't convert the whole scene ( convert all ) BUT only the Material Slots or Scene material only ans see if it goes right
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
HHbomb
Thanks, but convert slot material seems to do nothing...
HHbomb
Hi, Paride, justix is right... do vray version can make difference ? I use vray 3.60.03. Which version do you use ?
paride4331
Hi HHbomb,
me too.
could you try with 3dsMax 2017 instead of 2018? Same crash?
HHbomb
Hi, Paride, same with 2017...
Strange because it happen on just few models.... still searching
paride4331
Hi hhbomb,
I had few crashes, but I don't know why.
I sent my test and post crash files to developer.
HHbomb
Return to “Autodesk 3Ds Max”
