Creating seamless material
franchais
I've been trying to create seamless/non tiling grass material. I've tried using turbulence and the new uvw mapping but I can still see the tiles.
Any texture gurus out there that can help me out?
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
HHbomb
you need to combine multiple turbulence textures with different scales and orientations, there will still make tiles but at very far pov
Renart
You can use an OSL Texture node:
// Shader      : Texture Tiling OSL shader
// Author      : Hayssam Keilany
// Description :
// Meant to "break" the repeating patterns on textures
// Very simple version, could be improved by anyone if they feel like it :)
// REMINDER : YOU NEED TO USE "OSL UV" IN THE PROJECTION NODE
#include <octane-oslintrin.h>
color dissolve(color tex1, color tex2, float mix, float noisescale)
    float rnd = noise("noise", P * noisescale);
    color c;
    if(rnd < mix)
        c = tex2;
    else
        c = tex1;
    return c;
shader Texture_Tiling
  color texinput = color(1,1,1)
  [[string label = "Input (Texture)"]],
  float scale=4.0
  [[string label = "Tiling Scale", float min=0.0, float sliderexponent=4,float max=10]],
  int pixelate = 1
  [[string label = "Enable Pixelation",string widget = "boolean"]],
  int blurmode = 0
  [[string label = "Enable Blur Mode",string widget = "boolean"]],
  float blursize = 0.5
  [[string label = "Blur Size",float min = 0.0, float sliderexponent=4, float max=1]],
  float noisescale = 6
  [[string label = "Noise Size",float min = 0.0, float sliderexponent=4, float max=100]],
  output color c=0
  float u_tile; float v_tile;
  // "pixelize" the texture
  if (pixelate)
      u_tile = floor(u * scale);
      v_tile = floor(v * scale);
  else
      u_tile = u;
      v_tile = v;
  // offset it
  // can be changed to "cell" but voronoi looks more natural
  float u_jit = noise("voronoi", u, v_tile * scale + v_tile);
  float v_jit = noise("voronoi", v, u_tile * scale + u_tile);
  // add with untouched UV
  float xoffset = u + u_jit;
  float yoffset = v + v_jit;
  // declare the textures to blur
  color tex1 = _evaluateDelayed(texinput, xoffset           , yoffset           );
  color tex2 = _evaluateDelayed(texinput, xoffset+blursize  , yoffset           );
  color tex3 = _evaluateDelayed(texinput, xoffset           , yoffset + blursize);
  color tex4 = _evaluateDelayed(texinput, xoffset - blursize, yoffset - blursize);
  // choose between dissolve or blur
  if (blurmode) c = (tex1 + tex2 + tex3 + tex4) / 4;
  else
      color c1 = dissolve(tex1, tex2, 0.5, noisescale);
      color c2 = dissolve(c1  , tex3, 0.5, noisescale);
      c        = dissolve(c2  , tex4, 0.5, noisescale);
Just plug your map in the Input and don't forget to change the projection to OSL
franchais
thanks guys. How do I use the OSL text you have shown below? sorry abit new to this. I tried looking for the OSL node on standalone but I couldn't find it?
Hi franchais,
you need 3.08test 6, to try out OSL nodes.
before
before
after
after
texturetiling.orbx.zip
(2.5 MiB) Downloaded 462 times
ciao beppe
franchais
Thanks Bepe, that worked. Just one thing, where did you gett the osl editor on the bottom right of your image?
Hi franchais,
you need to enable the Script development option in Preferences/Application:
ciao beppe
v-cube
Hi bepeg4d,
I just tried this out and I have to say that this is totally A W E S O M E
That is for me like a real new feature of Octane! I tried this aproach with very bad tiling textures and got acceptable outcome!
I think this is a game changer for texturing with with bitmaps... and I could imagine it is just the beginning...
I really hope It will work within the Rhino plugin soon ...
thank you so much for posting!
best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Hi Andreas,
happy to hear that you are having fun with OSL nodes :)
Thanks to Hayssam Keilany for sharing this great script :)
Happy GPU-OSL Rendering,
ciao beppe
