My preview in octane camera and the final render is different. How do I fix? I might have changed some things myself, but can't figure out how to set it back.
Unfortunately it did not help.The display device was set to sRGB. Settings it to none Solved it. Thank you.
It's not a bug. It's beed discussed before. You need to set the proper values into Color management tab and enable Octane imager on active camera.Dmi3ryd wrote:Unfortunately it did not help.The display device was set to sRGB. Settings it to none Solved it. Thank you.
This did not help. Still incorrect display.J.C wrote:It's not a bug. It's beed discussed before. You need to set the proper values into Color management tab and enable Octane imager on active camera.Dmi3ryd wrote:Unfortunately it did not help.The display device was set to sRGB. Settings it to none Solved it. Thank you.
Same topic few lines below.
viewtopic.php?f=32&t=63100
