Timeline Render only rendering Alpha channel
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
tttlllrrr
Hello,
I am using Unity 2017.1.2 and the courtyard demo scene. I left all the timeline render settings to their default except choosing uncompressed. The rendered .exr frames seem to only contain alpha information when I open them in photoshop. How can this be remedied?
Thank you!
Xhed
How are your render passes set up for your active render target?
- Rick
tttlllrrr
I've tried a lot of different settings and can't seem to get an image with color.
Maybe a more effective approach would be if you are able to either recommend normal/common settings or share a unity scene that is set up correctly? Or screenshots of correct settings?
I am using the Courtyard for this test. I just want to use the timeline render to render a frame that looks the same as it does on the PBR Viewport.
tttlllrrr
Was able to get it to work! For some reason just deleting and re-creating the render target fixed the issue.
Return to “Octane for Unity”
