Bugreport: Layout Edit by Scene
ruuterdetuuter
Whenever I am in Layout and I set the Surface Editor by "Edit By Scene" instead of the default Edit By Object, Octane seems to get problems.
In this case the IPR keeps on refreshing until I change from one surface to another and back.
The Edit by Scene is especially usefull for FBX imports where dozens of objects get created with all the same names, and instead of changing every single lamp it's usefull to change all the surfaces together.
Could this be fixed in the next version or is it something in my own configuration?
Thanks in advance.
juanjgon
What are your LightWave and plugin versions? I'm trying to reproduce this problem here, but without luck so far.
If you can send me a sample scene with this problem, it could help a lot.
ruuterdetuuter
My Lightwave is the last version 2015.3
Octane is: 3.07.0.0
API: 3.07 Test 6
DLL Version 3070005
The scene problem occurs here with larger scenes...
Thanks in advance.
Return to “Lightwave 3D”
