So not as bad as matej get it. (Same driver, same cuda toolkit
Not file dependent, after a few minutes octane crash.
Gpu temperature controlled.
Blender exporter work so far and during work it works fine.
Testing further.
Cheers mib
Can you try installing the cuda 3.1 toolkit and drivers from: http://developer.nvidia.com/object/cuda ... loads.htmlmatej wrote:I can't render anything, because Octane crashes everytime![]()
* if I click on a material from live db
* if I click on a newly created material/texture node
* if I click on an imported scene node
The output is always the same (once it was no line 27):Code: Select all
Releasing cuda context on thread -694515440 Activating cuda context on thread -716576496 Cuda error in file 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx : unspecified launch failure.
Just change the setting in your preferences.ieatfish wrote:It seems Mouse Camera zooming is inverted by default (but not checked) compared to the last versions.
Yeah, it isn't a big deal by any means. Just wanted to point it out. I'm sure for some users, they would prefer it that way.radiance wrote:
We can change this for everyone if needed via octanelive without making a new release at any time.
Anyone against this ?
Radiance
I installed toolkit 3.1, but there was no difference. Then I installed also the drivers from the link - 256.40 (I actually had 256.44 before), and it's still crashing everytime it tries to start rendering.radiance wrote:Can you try installing the cuda 3.1 toolkit and drivers from: http://developer.nvidia.com/object/cuda ... loads.html
Can you try installing the latest linux drivers from the nvidia home page ?matej wrote:I installed toolkit 3.1, but there was no difference. Then I installed also the drivers from the link - 256.40 (I actually had 256.44 before), and it's still crashing everytime it tries to start rendering.radiance wrote:Can you try installing the cuda 3.1 toolkit and drivers from: http://developer.nvidia.com/object/cuda ... loads.html
And now beta22 crashes on startup (memory corruption)...
