There is no CUDA device which is supported by Octane Render.
remmac
Can someone help me with this?
I get the following message when I try to render:
Specs are these:
CUDA Driver Version: 9.0.222 (update required) > But that doesn't work...
NVIDIA GeForce GTX 780M 4 GB
3,5 GHz Intel Core i7
Cinema 4D R18
I checked the system requirements and it seems I should be able to use octane for cinema 4D
Hi remmac,
are you under Mac Os X High Sierra?
If yes, there is an issue with the current version on Nvidia drivers for High Sierra at the moment.
My suggestion is go back to Sierra, maybe installing it on an external hd temporarely.
ciao beppe
ATAGLIAS
Unfortunately installed High Sierra and having the same issue, tried everything to correct it but no luck...Do you think the bug will get fixed quickly ??
