Hi coilbook,
uncheck visible to camera.
OctaneRender® for 3ds max® v3.07 - 4.42 [OBSOLETE]
- paride4331
- stestb.zip
- (2.49 MiB) Downloaded 357 times
Hi Autodesk released 2018.3 3ds max that can create liquids using Bifrost solver . Will motion blur work with them http://help.autodesk.com/view/3DSMAX/20 ... 2C4B6DAC23
Update Update Update
Pls..
Pls..
3dmax, zbrush, UE
//Behance profile //BOONAR
BTW why no corona material convert.. I know you can't make them for all, but also I know you can afford to pay lawyers
- I know it's a cheap shot, but you know.. it's also true - you guys are doing your job, I'm doing my job, everyone's doing their job, I'm just a user that supports octane since 2010, wants to have everything working by now..
P.S. developers - Keep up the good work, don't let shitty comments get in the way of creating
3dmax, zbrush, UE
- Elvissuperstar007
- Contact:
+100000 2010!acc24ex wrote:BTW why no corona material convert.. I know you can't make them for all, but also I know you can afford to pay lawyers- I know it's a cheap shot, but you know.. it's also true - you guys are doing your job, I'm doing my job, everyone's doing their job, I'm just a user that supports octane since 2010, wants to have everything working by now..
Motion blur does work ok with 3ds max 2018 update 3 fluids
some problems foam is the same color as liquid, all foam bubbles are the same size, foam has no mb, octane mb duration must be 1 or liquids wont have MB, slow eval times . hopefully you guys can take a look at this new 3ds max fluid system thank you !
UPDATE:
please disregard foam color it is done by using multi subobject material
and size by changing size channel to density.
Problem is foam is still generated as slow mesh. Can otoy in the future as procedural foam like autodesk made it for arnold called Arnold Point because rendering millions of foam meshes will be impossible and slow
Also rendering foam only and no mesh create mb for foam but with strange mb direction. But having mesh and foam, foam has no mb Scene is attached
UPDATE:
- test.zip
- (96.59 KiB) Downloaded 321 times
- paride4331
Hi coilbook,
here it is.
here it is.
- stestc.zip
- (2.49 MiB) Downloaded 329 times
