ADDING UVW MAP crashes 3dsmax instantly
C. RAM Capacity (i.e. 6 GB)
- richardyarlett
ADDING UVW MAP whilst the LIVE VIEWER is running, crashes 3dsmax instantly. Very very consistant. Tried it on multiple machines. I have 3dsmax 2018 with OCTANE 3.06.4 - 4.41
- richardyarlett
Windows 10 latest version
2 x NVIDIA Geforce 1080
- richardyarlett
This is still an issue. I just updated to the very latest NVIDIA drivers and 3dsmax 2018 update 3 and Octane last version.
No change. Any attempt to ADD UVW to any scene, even just an empty scene with ONE object, immediately takes down the entire 3dsmax session hard. Can you please look into this asap. It is very frustrating.
It only happens with LIVE VIEWER OPEN, and only if it is running. If you PAUSE the LIVE VIEWER, then add the UVW MAP, and then unpause it, it is fine.
- paride4331
Hi richardyarlett,
I've done several tests, with win7 and win10, I can not find your issue, I tried it on my laptop, as you can see in the clip all seems to work.
Only doubt: are you referring to 3dsMax UVW MAP modifier? is it correct?
- 01.mp4
- (17.28 MiB) Downloaded 3130 times
