I have updated the installers at the top of this thread with:
3.6.3.31
- Compiled with Octane 3.06 TEST 4
*** NOTE: There is a known issue where the Nuke scanline node will crash when an OctaneMaterial is plugged into a Nuke Geo item connected to that scanline node. I am working with TheFoundry to resolve this issue.
OctaneRender 4 for Nuke [OBSOLETE]
Following is an experimental release compiled with Octane 3.07 test 3. Make a backup of your scenes prior to saving your scene after using this version of the plugin, in case you need to revert back to the previous version of the plugin. The new Scene Edit->Edit Octane Scene functionality provided by Octane 3.07 is pretty amazing, so take a look, although there are still some Octane API changes needed to get this working flawlessly.
3.7.0.34
- Compiled with Octane 3.07 TEST 3. See viewtopic.php?f=33&t=62636 for details.
- The OctaneRender node Scene Edit->Edit Octane Scene now uses a new NodeGraph window, more closely matching Octane Standalone, and allows the use of gizmo's to move Placement nodes. The OctaneReferenceGeometry node does not use this new nodegraph editor.
Nuke11 Windows ->https://render.otoy.com/customerdownloa ... _Win64.exe
Nuke10.5 Windows ->https://render.otoy.com/customerdownloa ... _Win64.exe
Nuke9 Windows ->https://render.otoy.com/customerdownloa ... _Win64.exe
I will provide Subscription, OSX and Linux builds once the next Octane API version is released.
3.7.0.34
Can you pls provide the information requested at the top of this thread. And what exactly do you mean by "can't install"?i can't install Octane plugin for nuke 11.v02
I have updated the TEST/STABLE installers at the top of this thread with:
3.7.0.35
The Subscription version of the above build should be available from the Subscription download area in the next few days.
3.7.0.35
Foundry have changed some API elements between Nuke11.0 and Nuke11.1 (https://support.foundry.com/hc/en-us/ar ... ns-of-Nuke), so I will need to do a separate Nuke11.1 build. I will do this when doing the next release. In the meantime, pls use Nuke11.0v* if you wish to use the Octane plugin with Nuke11.
I have updated the STABLE installers at the top of this thread with:
3.08.0.36
- Compiled with Octane 3.08
- The Nuke11 installer works for Nuke11.1v1 onwards (but not Nuke11.0)
3.08.0.36
Hello Paul,
I'd like to update my setup to Octane 3.08 with the latest Nuke plugin, but I notice that you specify an NVidia driver of 392.x or later as a requirement. Is there any specific reason it has to be more recent than the 390.x driver you specify for your latest Modo plugin?
I ask because, since I'm on Linux Mint 18, I have a choice between the recommended stable release 390.48 and the latest beta 396.24 - the latter solution being one I'd rather avoid for now...
In short, am I going to run into any problems with the 390.48 driver?
Cheers,
Roy
Linux Mint 18.1 64bit
4.4.0-62 kernel
128 GB RAM
4x NVidia GTX 1080
NVidia driver version 384.111
Nuke 10.5v7
OctaneRender for Nuke 3.7.0.35
Cheers,
Roy
4.4.0-62 kernel
128 GB RAM
4x NVidia GTX 1080
Nuke 10.5v7
Hi Roy - I think 390.48 will be OK. On Windows I had some crashes with the plugin with 392, and had to upgrade to 397.
