Im having some troubles with this, its hurting my workflow.
In the Octane node editor, when you select a node you get the info and options at the right side.
What i need is to get that panel (the info and settings part) and put it on the attribute manager... or in a separated tab. And then, delete it from its original position.
So i get all the info in the attribute manager, wich i have in a more predominat position (more vertical space).
I know it can be done, as i have seen it on youtube tutorials.
Any idea, please?
Thank you a lot
