Custom Aspect Ratio
SauceMonster
I'm using the c4d plugin and can't figure out how to change the aspect ration of the live viewer. My project is 3500x6000, is this not possible?
Hi SauceMonster,
Live Viewer has two horizontal lines at top and bottom borders that rapresent the current aspect ratio of the active Render setting. The horizontal dimension is fixed, while the vertical dimension changes to match the aspect ratio.
You can click the Lock icon in Live View to render at the same resolution of the render settings.
ciaoo beppe
