OctaneRender 3 for Modo [OBSOLETE]
When could we OSX users see an Test release for modo? Only windows is listed at the beginning... kind regards Thomas
MacPro 12 [email protected] Ghz - 48GB 2933Mhz DDR4 - AMD Radeon Pro Vega II Duo 32GB
I have updated the TEST builds for Windows and OSX at the top of this thread with:
3.07.0.125
- Built with Octane 3.07 Test 6
- Added Instance Color and Instance Range textures
- Added an instance id to each Scatter transform (ie. each Replicator particle source will have a unqiue instance id). The Instance ID is sourced from the Modo Replicator source IDs. The new Texture node types Instance Range and Instance Color can be used with these id's. Refer to viewtopic.php?f=33&t=62395 for for details.
- The Particle ID channel on a Modo Mesh Instance is now loaded into the Octane Scatter node Instance ID. You need to use whole numbers for the Particle ID to work (ie. 1, 2, 3, etc). The Particle ID of the Instance Source Mesh will be 0.
3.07.0.125
Hi Paul, thanks for the test build, but that doesn't work for me. After installing and starting modo 11 I get an error message with an unknown command.
face_off wrote:I have updated the TEST builds for Windows and OSX at the top of this thread with:
3.07.0.125
Hi - unfortunately there is a problem with the OSX installer I posted. I will post a fixed version on Monday.Hi Paul, thanks for the test build, but that doesn't work for me. After installing and starting modo 11 I get an error message with an unknown command.
I have updated the TEST installers at the top of this thread, with another interim build:
3.07.0.125
- Built with Octane 3.07 TEST 6
- Added Octane->General Visibility to Modo Area, Point and Photometric lights
- Added support for the Modo11 Mesh Light->Use Source Transform channel
- Added the Octane emitter Double Sided property to the Octane panel of Modo Area, Point and IES lights
This version should also resolve the OSX problem reported above.
3.07.0.125
Hi Paul,
The links to the on-line manual are not working properly. Can you fix?
- Capture1.JPG (16.25 KiB) Viewed 6452 times
- Capture.JPG (23.47 KiB) Viewed 6452 times
This is fixed in the next release.The links to the on-line manual are not working properly. Can you fix?
