OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
coilbook
HI Paride
I emailed you 3ds max file with phoenix fd and pflow in one scene
Could you please send it to developers so they can try to render sequence frame 500 and up.
Can they also try to render two version with " Disable Pflow mesh instances" CHECKED AND UNCHECKED
Our render times are crazy slow in the actual scene 7-10 min evaluation time for each frame not including rendering with both disable pflow instances on and off
Hopefully they can fix it. We are not sure how to render with this speed. Thank you!
Also the slowest times start happening after frame 1. with PF Source Updates
coilbook
UPDATE: It looks like slow pflow problems were solved using Disk Cache in Pflow.
We had to precache all firework particles. I guess when octane is ready to render next frame "processing geometry" it interferes with pflow calculation of the next frame particles. Scene loading went from 13 min to 19 seconds.
paride4331
Hi coilbook,
I already did the tests and sent the issue to developers yesterday.
ryan34side
Hello
i am using 3dsMax 2018 i have 3 x 1080Ti and 1x 1080ti for the screen and 3dsMax crashes using Youtube.
anyone to observe this problem?
No crashes on 3dsmax 2017 !
nico
paride4331
try to take a look here:
http://www.ismoothblog.com/2016/12/enab ... owser.html
ryan34side
paride4331 wrote:Hi,
thank you I disable all this bug is nevertheless particular because I use a map entirely dedicated to the screen and internet video ca should not crash
paride4331
hi ryan24side,
yes I know, but don't forget your dedicated video card works on 3dsMax too..
Did you test your crash using another render engine?
ryan34side
My problem is the same
error nvlddmkm
Display 4101
You know ?
paride4331
Hi ryan34side,
I do not know about this error, try to look at this:
https://forums.geforce.com/default/topi ... new-info-/
ryan34side
I think I found the problem I had a card that made that error 702 error I test all the cards one by one and that the fact that planting is what octane can damage the card to force to calculate on cuda ?
it's possible ?
nevertheless ca calculates but when I do other tricks it freeze and it is that with this card
Return to “Releases”
