2018 REVIT Compatibility
- newmountain
Hello, I just purchased the REVIT Plugin and am using 2018. When do you expect the plugin to support the newest REVIT version? Thx, Jason
Revit 2018 support is available now - the download link is in the first post of viewtopic.php?f=61&t=42589
- newmountain
Thank You! Awesome Plugin and the ORBX Export is worth the price of admission alone.
No - this relies on the Revit 2018 SDK, so it is not possible to implement in the Revit 2017 version of the plugin.Is there a way to update the revit materials transfer in Revit 2017? Similar to 2018 fix
Hi Paul
I have just installed revit 18.3 and the octane plugin doesnt bring in the revit materials into the plug in. I thought this was fixed in 18?
Is there a setting I am missing to switch?
FYI
Installed revit 18.3
Installed your plugin for 18
Opened file, no realistic material from 18 to octane plugin.
What am I missing?
many thanks in advance
FYI
What am I missing?
Hi. I installed Service Release 2018.3 and was unable to reproduce this problem. Can you send me a simple scene which demonstrates this issue pls.JNDesign wrote:Hi Paul
FYI
paul
my apologies.........
They do come thru if I perform "reconvert all materials from revit"
The only thing is they loose the scaling. it reverts to 1 scale factor so we have re scale all images etc.
Is there a setting that needs to be switched?
cheers
cheers
