Spotlight with Octane?
promity
In this (link below) thread in the Modo Octane group was discussion about possibility to create Spotlight-like lightsource with little node. Can we have something like this?
viewtopic.php?f=34&t=62905
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
Yes, I suppose that should be possible. It seems that the trick is to use the falloff and gradient node, something like this:
viewtopic.php?f=9&t=62903
I'll investigate it.
3dworks
have a look at this ;-)
octane_falloff_emitter.zip
(17.45 KiB) Downloaded 306 times
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
FrankPooleFloating
Nice! I'll have to play with this when I get a chance! Danke!
promity
Very interesting method - thank you!
Lightwave 3d
juanjgon
Thanks! This shader setup could be integrated as an option in the Octane_light objects. What parameters should be exposed from the nodes in the Octane_light GUI to control it?
3dworks
i need to experiment more with it, but i seems that 'falloff skew factor' in the falloff node and 'contrast' in the colorcorrect node are the most useful ones . the light color could be used from LW light dialog, to maintain coherence with other octane lights.
promity
Lightwave 3d
3dworks
promity wrote:Another one solution:
http://www.pixat.it/download/free/mater ... d-download
"Error You are not authorised to view this resource."
promity
Yes, you need to register.
Original message:
https://www.facebook.com/groups/lightwi ... 915763272/
Lightwave 3d
Return to “Lightwave 3D”
