No problem bud, maybe someone else or Sighman will chip in at some point? Not sure who is around these days/not looked yet lol. But do give me a shout any time if you dont find what you need here..like i say, IF i can help i willprotovu wrote:Ok then.......its me!
Wonder what to check.
Could be, the squirrel in my computer needs feeding.
Maybe Simon will suggest a reload of the plugin?
Thank you again for testing. So good to know there are other CarraraOctaners out there.
Best,
Rick
OctaneRender for Carrara 3.08.03.42[Stable and Test]
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
Hi Orion,
Just did a simple test file that did, in fact, work. (Sphere moving in an HDRI scene)
Could be that the files I am trying to use are simply too complicated. I believe that I gave them ample time to load.
Will try again later and give a shout if anything comes of it.
Best,
Rick
Best,
Rick
Thanks for the report. I'll look into it. In the mean time, I enabled livedb in the local Db tab. You can try to download materials from there.protovu wrote:Hi Simon,
I am able to duplicate a Carrara/LDB crash by simply scrolling down within the Cloth category. Haven't noticed crash yet in other categories, but duplicated 3 crashes in different files
searching Cloth.
Rick
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Hi Simon,
On the LDB, today, getting the following message when scrolling down:
"Buffer size is not sufficient".
And, of course, not able to scroll down.
Local DB lets me view, but not download into Carrara.
Rick
addendum......just crashed....But on Carrara reload, now able to scroll down and select in LDB....
.almost: it seems like trying to view the very last, or bottom most Materials, stimulates a crash.
Rick
Hi Simon,
I am having some problems with turning off shadows using the Octane Object Layer.
In particular, I would like to use an Octane enabled Spot light in my scene. Really like the controls you have enabled with the Spot.
Both the Spot and the Bulb are showing shadows, despite using the OOL modifier.
Rick
Rick
- shadow.png (67.53 KiB) Viewed 8195 times
