I run into this issue all the time and have been wondering what is the cause and why a 'shadow' from the light still remains when the visibility settings for a light are set to off.
Is it possible that the shadow is actually AO from the geometry of the plane, or geometry that is emitting light? I ask this because I had all the visibility settings on a light turned off and the light was clipping some geometry in my scene and it was still casting what seemed like AO on the clipped geometry...
Invisible Lights still visible
- ralf_breninek
- Contact:
Is it maybe the shadow from the light source itself?
I think I had this real world "problem" several times myself, because If you walk into a studio and light your scene you get shadows from your softboxes too.
C4D R21.207 / Octane for C4D 2020.2.4 / Watercooled 4 x EVGA Geforce RTX 2080 ti
http://www.pixelasm.com
Interface and motion graphics design for interactive interfaces and animations on TV, web, mobile and automotive from Köln / Cologne Germany
Try latest build with opacity=0 from light tag.
I understand the concept and of course it works like you described there is no doubt on that.
I am trying to avoid having the "square" reflection of light showing on the other objects. For eg on the sphere and on plane in this instance..
Is something like this possible?
Win 11 64 | RTX 4090 | Ryzen 9 5950X | 128GB Ram
- jayroth2020
You can try using a Rayswitch node with reflections disabled on the material, which will then not reflect the light. However, ALL of the reflections on that material will ALSO be ignored. Octane is physically accurate, and though there are some tricks here and there for some aspects, for the most part you need to manage situations like this in your scene and lighting design.
I don't use c4d, but one way to do this is to disable "visible to specular" on the texture emission node.
You'll need to find where that's done in c4d.
It's in light tagsfunk wrote:I don't use c4d, but one way to do this is to disable "visible to specular" on the texture emission node.
