Houdini Indie maximum render resolution
Houdini Integrated Plugin
allenh
Hi!
What would the maximum render resolution be for Octane when used with Houdini Indie for a single image? I understand Houdini Indie caps image sequence render res at HD, but imposes no such limit for Mantra/Prman when rendering a single image. Does this also hold true for Octane (e.g. if I wanted to generate a single image suitable for print?)
juanjgon
Octane has a 1080p (1920x1080) resolution limit while working in the Houdini Indie version, but only while rendering sequences. The stills rendering doesn't have any limitation. Be aware that all the file export options and the cloud features are also disabled in the Indie version.
Return to “Houdini”
