Character animation render problem
mate_karate
Hello, I have problem with simple elephant animation. Elephant is animated by bones, it got octane diffuse material, simple light and so on. On live preview - everything is working fine, but when im rendering out whole project - I got rendered oonly one frame. Take a look:
https://youtu.be/y9z5UF0SthI
I tried different Geometry Engine and Geometry Control without effect. Any ideas?
Hi mate_karate,
go to c4d menu Script/Console and copy paste the log output.
ciao beppe
raulofs
Hi.
Do you have standard material on the scene? I had a similar problem and I solved it. Try to remove the standard material and keep only the octane material. ;)
mate_karate
Thanks bepe4d and raulofs - standard materials were the problem :) I switched everything on octane4d material and worked perfectly. Solved!
Cheers
mate
