Rendering splines/hair with an emission render
ionoprea
Hi all!
I was wandering if it's possible to render splines with an emitting material?
I have a scene with a spline object with a octane tag on it. "Render as Hair" is check on the "Hair" tab.
What I want is to turn the spline in a light source.
I understand that since the spline is not a geometry it makes sense that the emission shader won't see it,
however I was hoping maybe there is a work around.
PS: Just to use a sweep nurb and generate geometry from the splines doesn't work for me cause I have LOTS of splines and will kill the viewport and octane.
Have you tried the blackbody emission with "Surface brightness=ON"?
VVG
aoktar wrote:Have you tried the blackbody emission with "Surface brightness=ON"?
not working
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
not working
Answer is NO for this case from devs. Hair primitives are not supporting the casting of any illumination.
vizualok
Link the trails to xpSplineMesher - there the emission will work - no more need for the hair tag
