I have model 8 millions polygons. Using octane 3ds max plugin.
When I open model (edit poly model with modificator mesh smooth), and try render it - 3ds max freezes. It can not handle it. I have 1080 TI, 128gb ram, 5960x core I7.
Previously was using vray and it was long render, but still rendering. Would be happy if you can help.
Freezes on high-poly models
- paride4331
Hi Ociacia,
polygons limit is around 40 million, so this should not be cause of issue.
Keep in mind polygons are stored in Vram but textures too;
Os and monitor/s need Vram: Window 10 eats 20% Vram, (win 7 less), your monitor/s are connected to 1080TI?
Other applications could use 1080TI Vram: photoshop, chrome etc.
Here is a reference to configure hardware with Octane Render:
https://docs.otoy.com/StandaloneH/Stand ... ptions.htm
If the textures cause the issue, you could try "Use CPU memory" in Render Setup > Kernel > rendering Setting and adjusting CPU memory limit option.
let us hear from you.
ociacia wrote:I have model 8 millions polygons. Using octane 3ds max plugin.
it is a bug with octane Another update on scene evaluation (octane viewport) and Phoenix fd.
version 4.39 with PFLOW disabled mesh instances takes 9 min 27 seconds to open 5gb scene with 5 fire grids.
version 4.38 - 2 min to open a 5gb scene with 5 fire grids.
Please fix it, otoy. We have 4.38 with wrong mb direction for liquids and 4.29 we cannot use because evaluation time is 5 items longer. So we cannot even work now.
4.39 opens faster with pflow disable but once phoenix fire sims are added it takes now 5 times longer.
