OctaneRender for Carrara 3.08.03.42[Stable and Test]
Carrara (Integrated Plugin developed by Sighman)
orion_uk
Hi Rick :)
Do you mean animation render from octane render settings rather than Carrara batch render?
I think you are looking for the following: animation output found at ....
Go to: EDIT/octane commands/open octane render window
Then selects open settings window (3rd icon out from left) and click on animation tab ;)
octane animation render
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
orion_uk wrote:....but, seeing as i have been 'away' from or4c carrara for quite a while batch render / animation render were seperate things when i was last about lol ;)
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
protovu
Hi Orion,
If I understand your meaning,,,,
I use Ctrl+Shft+R to get to what you are showing and it works great - when a Carrara file is already up.
Batch Queue is a different deal. No Carrara file needs to be up for it to load and render several .car files in sequence.
This can be really important for overnight renders of separate files.
orion_uk
Works for me!...or 'seems' to...it is completing each frame of the first scene file....waiting to see it moves on to the next scene file... How high are your samples for each frame per scene?
br3
br3
br2
br2
br
br
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
Final result on this quick test... (I did AVI but am sure PNG would be fine!) :)
User abort on first one as I wanted to try other scene files lol
end
end
batch
batch
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
protovu
Thanks for testing, ORion. Much appreciated.
Interesting.........I use sequenced .png exclusively.
Your steps were the same as those I indicated previously?
I Used these steps:
load file into Batch Queue
designate format and destination
select Octane Renderer from drop down
Launch
Also, please know that the Batch Queue did work for me with the previous, or prior to previous, version.
Finally, is it my imagination.....seemed that excluding load time for the initial first frame, render time for Batch queue rendering is slower than straight Octane rendering??
orion_uk
No problem (always happy to help, if i can!)..i am a little rusty though (sorry lol)...
Yes, those steps..doing a PNG seq set now...
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
All was ok with seq PNG's for me too ;)
fine
fine
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
protovu wrote: Finally, is it my imagination.....seemed that excluding load time for the initial first frame, render time for Batch queue rendering is slower than straight Octane rendering??
I think thats a human thing lol...just feels longer with multiple renderings going as you progress through the scene slower than waiting for a single project to com-plete/while it renders...building up the anticipation :P.... but if you do them one at a time....
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
protovu
Ok then.......its me!
Wonder what to check.
Could be, the squirrel in my computer needs feeding.
Maybe Simon will suggest a reload of the plugin?
Thank you again for testing. So good to know there are other CarraraOctaners out there.
Best,
Rick
Return to “Carrara”
